Brief Description: Installed Repaired Verical Power Control Unit
Installed Repaired Verical Power Control Unit. The Unit was giving false current readings on the Boost Fuel pump. Some circuit switches or breakers were replaced on the J4 Plug, including Pin 4 for the Boost Pump. All tests well now with the pump showing the correct 7-8 Amp draw.
