Brief Description: Found Out the GRT HX Can't Read IBBS Voltages
Found Out the GRT HX Can't Read IBBS Voltages! Connections were made because I had been lead to believe it was all doable. Now, I find out that the HX can only handle analog voltages of up to 12 volts. TCW says that the IBBS puts out 12-15 volts but they like to see a monitoring system that can handle 16 volts. I removed the Info wire from the CPC Connector ffrom the EFISs. The Info wire will be run to an LED light that I will install next to the cutoff switch. The light will illuminate when the battery is active. A ground wire was run to accompany the Info Wire at the light. The light was ordered from Stein.
