Brief Description: Attached Coolant Hoses to the Heater
Attached Coolant Hoses to the Heater. I had to wait for the arrival of 3' more of heater hose because the hose atached to the engine would not reach both fittings once the loop was cut. The 3 foot section was used for the connection from the water pump to the heater. The original hos from the water pump was used for the connection from the other heater fitting to the upper left side of engine where the route continues to the left radiator. The other hose on the water pump runs up to the coolant reservoir. This hose needs to be trimmed to length to remove about 8 inches. To be done next.
