Brief Description: Filled the Brake System with Royco 782
Filled the Brake System with Royco 782, Mil Spec 83282, brake fluid. This when very well filling from the bottom. I used an extra fitting nylon from my pitot static system that fit well into the top of the brake fluid reservoir on each master cylinder. The over flow was captured in a cup and there was very little mess.
I used EZ Lube on the threads of the AN fittings at the base of the master cylinders. This would eventually lead to leaking problems from both of the fittings. I drained the fluid from the system and used Permatex High Heat Thread Seal with good results (so far).
