Brief Description: Mounted ECU in the Fwd. Electrical Compartment
Mounted ECU in the Fwd. Electrical Compartment using AN4-14 bolts and 15/16" spacers to have the bolt heads clear of the ECU for easy maintenance.
Cut three 2" holes in the Fwd. Electrical Compartment panel for the passage of heater and ventilation hoses. One of the vents will provide heat to the pedals area, another will provide heat for defrosting the windshield and the last will be capable of providing eith cool air or heated air to the Right Panel Vent. The Heat can be blown to the rear passenger.
