Brief Description: Wired EIS to Eggenfellner Subaru 9 pin Connector
Wired EIS to Eggenfellner Subaru 9 pin Connector. There was some confusion as to what to do for wiring the tach input and the fuel flow input. Called Jan and was able to determine that the 6 pin comes off of a fuel injector and was used for the EIS fuel flow input. I found a different wiring schematic that showed that the tach wire is the #7 wire on the Eggenfellner 9 pin plug. This was wired to the EIS as the Tach input.
Completed the wiring of the EIS. On the EIS output 9 pin connector, the only wires used at this time is the EIS Output to the EFISs/VP displays and the Manifold Pressure output.
Ran grounds to the firewall for the fan and the Autopilot.
