Brief Description: Installed Two Engine Grounds to the Firewall
Installed Two Engine Grounds to the Firewall using 4 ga. cables. Applied dielectric grease to the terminals prior to securing the terminals to the firewall bolts of the Forrest of Tabs. Tested continuity with great results. The cables were secured both together, using silicon tape and zip ties, and to the engine mount with adel clamps.
