Brief Description: Made Several Firewall Penetrations
Made Several Firewall Penetrations.
Made a 1.5" opening for the engine control cables to pass through the firewall. I attached the pass through fittings fabricated from the stainless steel hand rail. Fire Block Sealant was applied to the firewall attachment before attachment.
Installed a firewall pentration for the passing of the manifold pressure to the EIS manifold sensor that I mounted just above the heater. The space seems to be well suited to the mounting os the sensor and the pass through.
