Brief Description: Riveted Fat Wire Firewall Pass Through to Firewall
Riveted Fat Wire Firewall Pass Through to Firewall. It was not pretty but it was functional. I made a small wedge of aluminum and drilled holes the size of the stem on the pulled rivet. Using the wdge, I was able to pull the rivets on an angle that allowed the rivet puller to be alway from the tight space.
