Brief Description: Checked Left Gear Leg Fairing after Installation
Checked Left Gear Leg Fairing after Installation after installation over newly glassed stiffener installation. The alignment pins were barely adequater in their maintaining correct fairing instillation angle. After rechecking the alignment and making corrections, Move the upper pin locations and installed additional pins on the bottom surface of the fairing to better set the correct fairing alignment.
Drew a rough alignment grid to assist with the visualization and fabrication of the Wheel Fairing/Gear Leg Intersection Fairing.
