Brief Description: Right Leg Fairing Too Tight After Glass Applicatio
Right Leg Fairing Too Tight After Glass Application. Tomorrow, I'll have to remove the fairing hinges and move them more aft on the inboard side. This increase in the trailing edge to hinge distance was first noticed when the fairing was fitted to the leg stiffener after it was bonded to the leg. The Fairing fit too tight then and I had to trim some stiffener off in order to get the fairing to fit the stiffener. Hopefully, moving the hinges will give me back some freemdom of movement in the fairing.
