John (Jack) Clark's Web Site
Date:  11-29-2011
Number of Hours:  0.25
Brief Description:  Checked the Right Leg Fairing Alignment
Checked the Right Leg Fairing Alignment using the lasar method. It showed that the fairing is very close to the correct alignment. The problem is that there needs to be some space available for the layers of glass to be applied once the stiffener is fitted and finished. I'll need to remove some more material from the stiffener for the glass.
