Brief Description: Confirmed Leg Fairing Alignment with a String
Confirmed Leg Fairing Alignment with a String drwn tight at two locations of 18" and 22" from the fuselage centerline. The good news is that the fairing to the string gap difference between the top and the bottom was only about 3/32". I did adjust the fairing position to equidistance between the strings.
