Brief Description: Fit and Drilled the Right Wheel Fairing
Fit and Drilled the Right Wheel Fairing just as yesterday with the Left Wheel Fairing.
Applied 1" four ply glass patch to the areas of contact between the U-808 bracket to buildup the area. This fairing area has a radius the needs to be filled so the U-808 bracket can make a flat contact when they are screwed together. Also applied a 3 ply glass layup over the area of contact of the U-810 bracket for strength and some fill.
