Brief Description: Installed the Brake Line to the Right Wheel
Installed the Brake Line to the Right Wheel. Used the supplied 1/4" aluminum tubing from Van's. I was considering the use of braided lines but decided to go stock to save wait. If the lines have worked on so many Van's aircraft, I expect it should be fine for mine. I still need to secure the lines by putting a split tube around the brake lines every 12" and then tape the lines to the landing gear leg. The loops of tubing will provide some degree of flexibility.
