Brief Description: Re-wired the EFISs and AHRSs Secondary Power
Re-wired the EFISs and AHRSs Secondary Power. This included running new separate secondary wires to the AHRSs and inserting these wires into the secondary AHRSs power pin locations separate from the primary AHRSs power pins. The original wiring had both primary and secondary power going to the same power pin for the AHRSs.
I'm using a CPC for the first time to wire the EFISs and AHRSs primary and secondary powers. The TCW IBBS Info Wire is also within the connector.
