Brief Description: Connected Fuel Guardian and Autopilot Wires
Connected Fuel Guardian and Autopilot Wires that have knife splices on them for easy separation should the panel need to the removed. The splices were covered with shrink wrap.
Reinstalled the ADS-B Fault Light after panel was touched up. Still need to splice wires to the light. The ADS-B out for the Fault Light is a ground. If the ADS-B faults, it connects to ground. Therefore, I need a power wire to the light. I will probably install a low amp terminal under the panel for such needs. I'll get the power from one of the fused terminals on the baggage compartment bulkhead.
