Brief Description: Installed the ADS-B Fault Light in the Panel
Installed the ADS-B Fault Light in the Panel next to the Master Warning Light.
The AHRS Mount attachment to the instrument panel is with screws that have 100 degree heads. These holes were machine countersunk.
The above holes left areas of the panel needing repainting. I masked off these areas, very lightly sanded the areas with 400 grit and spot re-painted the instrument panel. The results were good.
