Brief Description: Ran Panel Dimmer Source Grounds to the Terminal
Ran Panel Dimmer Source Grounds to the Avionics Terminal. The dimmer instructions say to avoid grounding sources locally. Therefore. I ran the gounds to a free post on the Avionics Power Terminal. From there, they will return to the dimmer and then to to airfame ground.
