Brief Description: Soldered the Mini DIN Connector for GPS to ELT
Soldered the Mini DIN Connector for GPS to ELT. Lacking experience with soldering small connections, I took my time and through trial and error, ended up with a fairly good connector. I did manage to melt a small amount of the connector plastic with the iron heat. This was superficial and the connector is quite functional. I sealed the wires inside the connector and at its tail using E-6000.
