Brief Description: Drilled Holes in the C-804 Slider Cap
Cut a taper in the forward end of the Spacer Rail per instructions so that it will fit properly in the receiver.
Drilled Holes in the C-804 Slider Cap after marking the Cap for equally spaced rivet holes. If I was smart, I would have drilled the holes on the drill press. As it was, I free drilled the holes and the result is that the line of rivets has some variations. Call it 20-20 hind sight. It is nothing of a functional concern but it is somewhat of an esthetic concerns.
