Brief Description: Drilled and Attached C-803 Rails to F-816
Drilled and Attached C-803 Rails to F-816 Canopy Rails. I attached a mini-nutplate to the underside of the F-816 for the first forward attachment screws of the Roller Rails. This was because this screw is within the space of the center section bulkheads that will be covered by the riveted cover cap and there won't be access to the nuts that the plans call for in this location.
