Brief Description: Programming G430W and GRT EFISs
Programming G430W and GRT EFISs after receiving council from the equipment Reps. I talked to the GRT Reps for problems I encountered getting correct results on the ARINC channels. Turned out that some of my inputs were incorrect. I based by input info off of an information sheet and drawing that I received with my Approach FastStack cables for the GRT EFISs. The problem is that the sheet by itself is confusing as to what is wired to each input/out pin. After talking to Tim Haas at the Approach Display, I discovered that the best source of wiring information is on a wiring map that Approach provided me with my first shipment. I did not remember receiving it but once I found it and used it, the inter-device wiring became much clearer. As a result, I had some significant progress with the programming of the equipment. The wiring map helped immensely with the configuration of the G430W so that it could communicate with the GRTs.
