Brief Description: Installed an Inline Fuse for the Fuel Guardian Lig
Installed an Inline 0.25A Fuse for the Fuel Guardian Lights at the Instrument Lights Dimmer Terminal Strip.
Soldered a 47 ohm resistor inline for the Master Warning light that comes off of the GRT EFIS. If my math is correct, this will limit the current to a max of 0.2A as required by the stated limit. The light is being run through the Instrument Lights dimmer so this max should not be seen in normal circumstances.
