Brief Description: Installed and Wired the Panel Grounding Hub
Installed and Wired the Panel Grounding Hub. This hub provides a convienient place close to the avionics to run all ground wires. I expect it to help maintain order of the wires behind the Panel. There will be five 20ga. wires run from the hub carryt current to the grounding Forrest of Tabs on the firewall.
Fabricated a mount for the hub per instructions using aluminum angle.
