Mounted the Fuel Guardian on the left side of the front baggage compartment. The Fuel Guardian will alarm for each tank once the fuel uncovers the optical sensors place in the tank inboard bulkhead during construction of the tanks. The exact point of alarming will be discovered once the tanks are filled for the first time.
Spliced the audio output from the Fuel Guardian and the AoA audio output to the Audio Panel Unswitched #3 wire per Tim Haas' from Approach FastStacks.
