Brief Description: Wired the Bottom Row of Avionics Power Terminal
Wired the Bottom Row of Avionics Power Terminal that was installed on the forward side of the Aft Bulkhead of the Forward Baggage Compartment. The wires come from the Vertical Power Control Unit mounted in the rear. These wires power the G-430W Nav and Com, Com #2, Transponder, Audio Panel, GRT EFIS displays, pilot and co-pilot Push-to-Talk switches, Autopilot power, Autopilot disconnect from the stick grips and one extra power source that is unused that is used for 3A of regulated +14 Volts power. The last one I have no idea of a good source with which to use this source of power.
Installed two fused power panels on the forward side of the avionics acces door. One panel will be used to power the equipment associated with the Backup B. The other fused panel is an extra source of up to 10A of total power. I'll use this for future equipment additions and as a needed convenient source of power.
