Brief Description: Attached Cables to the Aft End of Avionics Trays
Attached Cables to the Aft End of Avionics Trays. This was a challenge because there is very little space in which to work to install small 4-40 screws from the inside of the trays to secure the connectors to tthe trays. The only radio stack connector not attached is the one for the Transponder because it is already in the aircraft as part of the ADS-B Cable wiring.
