Brief Description: Installed the ADS-B cable 37 pin D-Sub Connector
Received FastStack Cables and Avionic.
Installed the ADS-B cable 37 pin D-Sub connector aft running the cable aft to the unit. Had to drill holes through the bulkhead and install snap bushings to accommodate the size of the cable. The ADS-B makes its connection to the Hub through the Transponder connection. The 9 pin D-Sub connector for unit maintenance and programming is located on the forward end of the cable and will be mounted in a hidden but accessible location.
