Brief Description: Organized Forward Right Cabin Wires
Organized Forward Right Cabin Wires. Drilled holes and inserted snap bushings in the horizontal lip in the right corner of the aft baggage compartment bulkhead. This provided routing access to the back of the instrument panel for the wires that ran along the floor as well as the wires that ran forward under the canopy rail.
Pulled the wire that was to be used to power the EIS. The EIS is going to be powered off of the Backup B Fused Terminal that will be installed on the aft baggage compartment bulkead. The lead from the VP CU will now be used to power the ADS-B. This wire was pulled from the bundle and is ready for use with the ADS-B once that cable is installed.
