Brief Description: Organized the Wires/Cables of Rt Fwd Cabin Floor
Organized the Wires/Cables of Rt Fwd Cabin Floor. Several snap bushings were installed to in the forward right bulkhead to allow routing of the wires/cables to the rear of the instrument panel. A conduit was used to run the main grounding cable and the other smaller wires that also pass through the same spar center section hole towards the bottom of the forward right bulkhead. Later, I'll secure the conduit with adel claps to prevent movement. Same for the coax cables that are running through the other hole on the right side except here I plan to use a split conduit.
