Brief Description: Started Fabrication of NavWorx ADS-B Mount
Started Fabrication of NavWorx ADS-B Mount. I will be mounting the device in the tail on the left side.
Cut and bent the aluminum sheet that will have the ADS-B mounted onto it. The pieces of angle that will have the mounting panel screwed to it were cut and match drilled to the longeron. The upper screw holes were drilled.
