Brief Description: Polished 0.5 of the light corrosion on Rt Wing
Polished 0.5 of the light corrosion on Rt Wing. This corrosion formed at the edge of the protective vinyl where it had been removed for riveting parts. The most noticable areas seem to be around the tanks. I had purchased some aluminum polish at Sun 'N Fun awhile back. This mad short order of removing the light corrosion areas. I will return to the hangar to remove more but I will bring the dual action buffer. It can run slow which is neede to use a buffer with the polish. There is too many spots of corrosion to do the removal with finger swirls.
