Mounted the Front Throttle after first disassembling it. This was necessary to re-build the throttle in place on the mounting plate. The single lever throttle mounting holes do not match the pre-drilled holes in the mounting plate. Therefore, I had to drill matching holes and enlarge the friction knob hole to accommodate the washers that need to fit into the hole. These washers are compressed against the brown composite material that sandwich the throttle level thereby increasing lever friction.
