Brief Description: Re-checked the aileron neutral positions
Re-checked the aileron neutral positions. Ther was a mis-alignment after installing the aileron stops. After resetting the neutral positions of the ailerons, the aileron up and down limits were much better. The Left Aileron had a range of 31.5 degrees up and 16.9 degrees down. The Right Aileron had a 31.4 degree up deflection angle and the down deflection was 16.9 degrees. These were good numbers, both consistent and within an acceptable range of motion.
