Brief Description: Checked the Ailerons' Range of Motion
Checked the Ailerons' Range of Motion and found that the ailerons moved up about 33.0 degrees and the down motions was about 17.3 degrees. This was out of the acceptable ranges for 25-32 degrees up and 15-17 degrees downward deflections. Was unsure of how to improve the range findings particularly since I had just rechecked the neutral alignment of the aileron and control stick pushrods. Will call Van's for information.
