Brief Description: Match drilled the Fuselage Center Skins and Wing
Match drilled the Fuselage Center Skins and Wing Bottom Skins. The Wing Bottoms Skins are covered by the Fuselage Bottom Center Skins. Using lines drawn earlier on the wing bottom skins, matching holes were drilled 3 inches from the beginning of the line. Most of the holes did line up with the matching holes of the wing when the fuselage center skins were drilled to #30. A couple were off and will have to be corrected later. The forward most holes wer not drill due to the saw horse being in the way.
