Brief Description: Re-measured the wing required for rear spar drilli
Re-measured the wing required for rear spar drilling. This time, with greater scrutiny. The hanging bobs showed a slight discrepancy in the inboard bobs. This was confirmed by a difference of about 4-5 sixteenths of an inch between the compared wing tip to tail measurements. Through a slight adjustmentt of the left wing sweep, tha tip to tail measurements were right on and the four bobs were right on the line.
The angle of incidence settings of the wings were re-checked and adjusted as needed while the wing tip to tail measurements were continuously monitored.
