Brief Description: Set the wings' angle of incidence
Set the wings' angle of incidence by first cutting a block 2 51/64" tall. The front edge of this block was placed on the web of the rear spar. the front of long level was placed on the web of the front spar while the back of the level rested on the block. This setup was used to set approximately a positive 1/2 degree of incidence angle in the wing. This angle is achieved when the wing is moved up or down at the rear until the level indicates level. Surprisingly, both wings measured nearly perfect as setup initially. Little to no movement was needed to set the angle. The leels were reading between zero and 0.1 degrees.
