Brief Description: Tested VP CU Plugs/Pins for correct wiring
Tested VP CU Plugs/Pins for correct wiring using the Buzzer Circuit Tester.
I had run a single wire to power the Cowl Flap through a switch. I decided to have two wires run, one for the up motion and one for the down motion. To do this, I had to use one of the unused pins of the J-6 plug on the VP CU. It was necessary to undo the wire lacing from the CU and the right bundle under the armrests to run the wires. While I was at it, I cut the terminal off of the Pitot Heater wire that was in the wing and inserted the terminal that was already on it into its location in the J-6 Plug. It is easier now to do this then having to crawl back aft after the tail is closed.
I used another unused 18 amp pin position on the J-6 plug for a 14ga.wire that I left coiled in the back by the VP CU. This wire will power a fused terminal block from which I will be powering the remote mounted NavWorx ADS-B transceiver. This will also be a site for powering future additions that require a source of power.
