Brief Description: Secured ground cable in the mid-cabin
Secured ground cable in the mid-cabin with adel clamps bolted to the right seat rib.
Installed a nutplate for the adel clamp that secures the laced wire bundle on the left aft center section bulkhead as the bundle traverses from under the armrests to the center section bulkhead conduit. This neeeded to be done because there will not be any ready access to the nut after the center section is finally closed off.
