Brief Description: Ran another power wire for the cowl flap control
Ran another power wire for the cowl flap control. Initially, I was going to control the cowl flap using an intermittent switch for up and down. I decided to run another power wire from the CU for the cowl flap. Now, I have one for UP and one for Down. The CU will be programmed to automatically control the routine positioning of the cowl flap. I will still be able to manually position the cowl flaps either through the display unit or I may install an external switch wired via the display unit.
I used the pin position that I had planned for the ADS-B installation for the Cowl Flap UP and used the already installed wire for the Cowl Flap for the Cowl Flap Down.
