Brief Description: Cabin lighting, wire protection, and clean up
After pulling apart the forward main wiring runs and pulling the smoke line I needed to run two lines back across the fuselage from the left side to the right, under the canopy rail for the cabin lighting. Once complete I zip tied on the wire protection again. Patterned the front fire wall for heat shield to aaply on both interior firewall noise reduction as well as exterior heat shield. I also attached the rear cabin.
I also received my canopy cover I ordered at Oshkosh.
