Brief Description: signal line from grip to bagage compartment
It really sucks to back track. I found, after pulling my main lines through the fuselage and attaching rash protection and zip tying everything down that I did not have a signal line for the pilot stick. I had to cut zip ties, pull rash guard, push out rubber grommets; then pull a line through to the smoke pump relay location. (Still some work to go; but good progress for 4:30 AM prior to work).
