Brief Description: Firewall insulation and heat shield
I had tried to put together a card board patern of the forward fuselage. I drew centerlines between the motor mounts anbegan measureing from center and found my pattern was off a bit since I had taped pieces together to make the whole pice. Cut the final pater from the textured aluminum with a fiberglass insulation. Removed a middle section of the release papter and worked it out from center. Not perfect, but turned out really good Reattached the master cylinder and pullled the three control cable through the firewall and to the throttle position location. Wired and pined the boost pump connector.
