Dave's RV-10 Build Log
Date:  10-24-2019
Number of Hours:  7.00
Brief Description:  Wing Fairing Nutplates, Tank Attach Bracket
Installed nut plates onto the wing root fairing supports per plans using a pneumatic squeezer.
Installed nut plates on the fuel tank skins for the wing root fairing outboard support.
Riveted the tank attach angle F-1054 to the tank attach bracket T-1005 by driving with the rivet gun and bucking with the other hand. Determined that with help I should be able to complete the work on the wing root area without having to remove the wings for access.
Removed the front seat rails and covers to be able to reach the back side of the rivets for the wing root fairing supports inside the fuselage sides.
