Dave's RV-10 Build Log
Date:  5-13-2020
Number of Hours:  6.50
Brief Description:  Installed Wheel Fairings
Installed wheel pants on all 3 wheels. Installed gear leg fairings on main gear legs. Installed interface fairings on main gear legs. Had to drill larger #28 holes and countersink for attachment screws on the interface fairings. (Had match drilled the install screw holes as #40 and attached the nut plates to the wheel pants and rivnuts to the fuselage bottom, but didn't drill out the holes in the interface fairings for the mounting screws.)
In order to install the nose gear fairing, had to remove the snorkle. Had to trim the fairing to eliminate interference with the center rear support plate F-10108B. Installed the nose gear fairing. Re-installed the snorkle.
