Brief Description: Auto Pilot Ground Tests, Adjust Oil Press Alarm
Conducted the Auto Pilot ground tests per the G3X Installation Manual. Needed to reverse the pitch servo direction. Set the servo's to 50% torque and tested that I could overcome the servos with the stick force.
Adjusted the oil pressure low warning to 50 psi, since the alarm was triggering at idle when hot with it set to 55 psi.
Played with G3X PFD/MFD on ground power to improve my understanding of the displays.
