Dave's RV-10 Build Log
Date:  3-10-2020
Number of Hours:  5.00
Brief Description:  Installed Fairings & Data Plate. Modified Seats
Replaced the data plate on the tail cone with the new one with corrected name order to match registration (Macdonald David R).
Installed wing root upper fairings. Installed empenage fairing.
Added MK1000-3 nut plates on the seat adjusting body for both front seats to allow bolting the adjuster to the seat from the inside with the bottom cushion lifted. This allows easier install/removal of adjuster which is required to clear seat stop to install/remove seats.
Trimmed the front/forward ends of the HDPE seat rail inserts by 1/2 inch to allow removal/install of the seat without removing the flap torque tube covers. Re-clocked the seat back angle adjusting levers by 90 deg. to make it easier to reach these levers with the seats installed.
