Brief Description: Wing tip modification for hing mount
Finished up riveting the hing mount to the right wing tip. Riveted in the rear brace for the fiberglass.
Second time around I used far less fiberglass for support and I clamped on a metal edge to cut the wing tip so it was much cleaner. Overall fit is similar on both wing tips, but just a little tigher gap between the aileron and wing tip on the right tip versus my first attemp on the left wing.
